23-04-2012, 02:21 PM | #181 | ||
Sorry typo... Meant 0.84 lambda, and plugs were ngk iridium 7's gapped at 0.76 and we slowly went down to 0.6 and the same thing was happening... I just thought the factory Ba coils weren't providing a strong enough spark to burn e98.
Daily driven workute....10.33 @ 136mph
Gtx3582 Stage 2 Nizpro kit. HEADSEX TUNED |
23-04-2012, 02:39 PM | #182 | ||
Where you tunning with SCT or VCM Suite, where you adjusting the spark dwell etc. Also you may be better off with copper or silver plugs.
You could also look into KB boost-a-spark. |
23-04-2012, 03:35 PM | #183 | ||
Sorry typo... Meant 0.84 lambda, and plugs were ngk iridium 7's gapped at 0.76 and we slowly went down to 0.6 and the same thing was happening... I just thought the factory Ba coils weren't providing a strong enough spark to burn e98. Boost was 16.9 psi, using std factory gt3582 turbo.
23-04-2012, 04:03 PM | #184 | ||
Did you throw a fresh set of coils on her mate?
Im at 1.1 gap with 16psi with the boost'a'spark. |
23-04-2012, 04:07 PM | #185 | ||
E98 is harder to ignite then E85 for instance. but, it should be able to cope i have seen them running more boost on other XR6T's using standard ignition setup.. the copper plugs should ignite better than the iridium.
it's a big gap, we are down around 20-thou, im not familiar with what the BA's like, maybe try asking in the FPV XR6 etc secton what the other guys are running. with the Hyundai/M&W coils with just the igniter we could run E90 up to 27psi, however, this was a different engine. get a hold of some -8 NGK Coppers and have a go. dwell can/will make a big difference, if he changed the dwell and it doesn't have enough time to charge the coil then it won't be a big spark. i have seen it with the LS guys, the LS1 coils take 5ms to fully charge, anything under 2.5ms and spark would blow out at higher boost. |
23-04-2012, 04:33 PM | #186 | ||
I found the BF coils are better.
23-04-2012, 04:38 PM | #187 | |||
23-04-2012, 04:38 PM | #188 | ||
I find mine are better than all of them lol!
Sure am running 1.1 gap,I have my own std modified coils and the ignition booster upgrade.I recon I can go wider on the gap again but ill risk frying my coils I recon if I turn the wick up on the controller Cheapo plugs to FTMFW |
23-04-2012, 04:42 PM | #189 | |||
Cheers.
23-04-2012, 04:43 PM | #190 | |||
I also run a single 3" exhaust and less than 3" intake.......shhhhh,dont tell anyone it works |
23-04-2012, 05:51 PM | #191 | ||
i went 11.3 with a 3" exhaust on my Ba with std intake and crossover, back in 2008.
24-04-2012, 08:17 AM | #192 | |||
24-04-2012, 08:33 AM | #193 | ||
Ill try a .8 gap prasac next time it goes back and run it up to see if their are any advantages on the same tune,if its the size of a bees **** dick the gain ill still take it.Lots of bees ***** equals a big bees ****I think because of the relatively low boost its coping well.
I hear what your saying though,its like trying to push over a small fat guy compared to a tall skinny fella,the skinny fella will drop first every time. |
24-04-2012, 12:07 PM | #194 | |||
better spark, more eficient burning + more fuel = more power. it might not show power, but, it will be better for it. you do have the lower boost helping you, once you start pushing it, will really make a difference Last edited by prasac; 24-04-2012 at 12:13 PM. |
24-04-2012, 01:56 PM | #195 | ||
LOL i ran 1.4mm and 1.5mm gaps running LPG with no break down. I found it performs best at 1mm gap. Most people are using 0.8mm when running LPG.
Its worth testing to see what works best for your setup. Its always good to compare other peoples setups, but nothing beats your own testing. Plus you its rare that you get the full story or full details. |
24-04-2012, 02:15 PM | #196 | ||
Critical Thinker
I was told to run between 0.8-0.9mm gap for my plugs for best performance. Not a massive difference but noticed it picks up ever so slightly quicker from stand still compared to a 1.1mm gap.
24-04-2012, 02:29 PM | #197 | ||
it would be good to see alot more cars on E85. it has been around for a while now so tuners should be getting better and better with it.
24-04-2012, 02:41 PM | #198 | ||
I think if E85 was 85% accross the board you would see more cars and tuners using it.
24-04-2012, 04:13 PM | #199 | ||
Anyone tried Martini's new E85? Has a 116 octane rating, which is the highest I've seen in E85.. Looking at doing a comparison in the next few weeks against Sucrogen which I've always used..
Wish we had United E85 in Brisbane!!!!
Old ride.. FG F6 610rwkw Built and Tuned by Profile Autosports |
24-04-2012, 08:29 PM | #200 | ||
I'm with you Ben ,would be good to have it a little more available in brissie!
blueprint ba turbo ute,powerglide, Old set up -9.9@140 1.57 60ft 720rwhp New set up 1003.4rwhp yet to be run! Tuned by Forced performance and tuning. |
24-04-2012, 09:29 PM | #201 | ||||
we have really only noticed a pickup in torque, Race E90 blended with refined Premium ran 8.20@166, United E85 has run 8.30@167. it did 60' better with race mix, it could have been track prep, if u go with mph they are pretty similar, however pump shows a lil more mph. |
24-04-2012, 10:19 PM | #202 | ||
thought i would add this, its our little E85 test kit. costs around $30, you can get the test tube from ebay etc and the syinges from the chemist or your local junkie
the fuel and ethanol separate, tested a E98 batch we have, as you can see it separates and the fuel, lubricants etc float to the top leaving you with what % of ethanol is in there, this is around 98%. a mix like this, should give more power and torque |
25-04-2012, 12:28 AM | #203 | ||
Do you have a link for a Aussie seller paulie?
25-04-2012, 01:07 AM | #204 | |||
28-04-2012, 08:01 PM | #205 | ||
donkey22
e85 all the way
29-04-2012, 09:10 PM | #206 | ||
not that it's need, but confirmation again of just how good United E85 is.
car is 170lbs heavier, has full exhaust including 2 cats and is on a 275 M/T ET Street Radial http://www.youtube.com/watch?v=m_aYDZlaEwc |
30-04-2012, 08:47 AM | #207 | |||
30-04-2012, 02:24 PM | #208 | ||
I think you'll find the martini stuff is ethanol mixed with their m109 Unleaded race fuel . Hence the nice big octane rating . 85% ethanol 15% 109 yummy !!!..
I think the point everyone is missing , is the octane rating ! Yes it's all 85% ethanol , but if they are mixing the 15% with 91 grade fuel compared to 95 or 98 , then Obviously the octane has changed .. I think this may explain some engines suffering inconsistencies in power and track times ( as I've always said to you Paul ;) ) . Where the drum race stuff is consistently mixed with the same grade gasoline giving consistent Octane ratings and power outputs !
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
30-04-2012, 03:07 PM | #209 | |||
30-04-2012, 04:03 PM | #210 | ||
If your running martini e85 I'm assuming you don't have a Kia ;)
I'll put it another term ... If I told you gasoline was 100% no ethanol would you tune on it with knowing its either 95 or 98 octane ? Answer is NO every time . Anyways I hope people understand my point . Yes E85 is great , but until they show an octane rating , then I doubt you can tune consistency into it unless tuning for each batch like Joes Capri .
