Just replaced intake manifold gaskets and noticed this vacuum line is not in great condition and needs replacing. Does anyone know what size it is? thanks
![]() Join Date: Oct 2006
You don't say (and you should always state: model, year, engine and trans configuration so we are not left playing detective) but I guess we have to presume it's your 97 EL again. It might also be more appropriate to post in the relevant section here https://fordforums.com.au/forumdisplay.php?f=29 or even https://fordforums.com.au/forumdispl...er=desc&page=2 rather than in the Pub. In any event, I suggest just measure it with verniers and get the closest fitting size here: https://www.supercheapauto.com.au/se...ose&lang=en_AU or take the old one to Supercheap or wherever and match it.
regards Blue Last edited by aussiblue; 07-05-2024 at 05:34 PM. |
Experienced Member
Always bet on 3mm.
If it ends up being 4 or 5 mm then there's a chance the 3mm could still be forced on with hot water or heat gun. Vice versa no good and will leak ![]() Seriously though, that looks old, looks like 5 mm. |
around the place
get some 4mm i.d silicon hose. re-route it from the reg around to that barb furtherest from it so you get a decent bend diameter on the hose. the hose that was on that furtherest barb, move it to the one closest to the reg.
GPS Tracker for your vehicle - PM me for info |
