Old 11-06-2015, 04:13 PM   #31
XYwagonAU
Default Re: How to Ajust or Replace Hand Brake (IRS)
hi easyboss,
i wrote that post a while ago,
give me a ring on 0428746617 and ill try to explain...........
only just realized you are in NZ
im in AU, so youd have to ring +61428746617 (i think)
XYwagonAU is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2015, 04:28 PM   #32
XYwagonAU
you can access the adjustment without taking the disc off
to tighten you turn clockwise- but because of where the access 'window' is, you have to turn it differently on each side,
the hole to access adjustment has rubber grommet over it
the adjusting wheel has lumpy bits (like castellations)
you push the wheel with a screw driver- either levering toward you or pushing away - as wheel is perpendicular to disc (horizontal)
get a torch and try to see what is going on it there..
im not sure but i think i jacked both rear wheels off the ground, put vehicle in neutral, handbrake off, turn one of the adjustment screws a bit / then test- you want the brake to come on by 4th click apparently
btw - im definitely not a mechanic (any only tried this on AU wagon - disc brakes no IRS)
if you dont get any joy you can take disc off then you will see what is going on...........
Old 11-06-2015, 04:32 PM   #33
revcore
revcore's Avatar
This is fantastic information. My handbrake requires adjustment too...saves me starting a new thread now.
Cheers for the write up/info fellas.
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2015, 04:35 PM   #34
EASYBOSS
Matakana NZ
EASYBOSS's Avatar
^^^ thanks I'm in NZ, were are you, guessing you cant remember what direction for what side, so I might have to take on drum off to work it out, maybe not a bad thing as I could also check out the shoe wear
SOLD : BA XR8 4 Speed Auto in Mercury Silver, Bluepower CIA, Full Diffilipo Big Boy Quad System, Tune, 4.11 Diff Gears, FPV Starter Button, FPV GT Rear Spoiler, Tripod Gauges, PWR Trans Cooler. 230 RWKW's. Many thanks to Chris at Bluepower Racing Developments
Hers : F6X build #150 in Ego, Stock as a Rock, untill the warranty runs out, including the extended one.
My Work Wagon AU Futura Wagon in Gold.
On the Farm : Ford 6600 Tractor
EASYBOSS is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2015, 05:14 PM   #35
XYwagonAU
clockwise to tighten - if you imagine the adjusting wheel from above - see old post .......
"-left/ drivers side, tighten by levering toward yourself
- right side, tighten by pushing away"
Old 11-06-2015, 05:41 PM   #36
XYwagonAU
http://www.fordforums.com.au/showthread.php?t=11418260
found this pic on forum..........courtesy - "phildo"
also first step is to turn the disc/drum around so that you can find adjustment screw.......
File Type: jpg BF_Falcon_Rear_Axle_Bearings_23_23_3_2014.jpg (82.8 KB, 206 views)
Old 12-06-2015, 04:32 PM   #37
revcore
revcore's Avatar
I adjusted the handbrake cable inside the ute today and it only just holds the vehicle so tomorrow I'm gonna adjust it by removing the rear wheels. Hoping I can get a screwdriver in the inspection hole and adjust it like that. If not I'll remove the discs and adjust it that way.so it's clockwise for both left and right sides?
My Ride...
Old 12-06-2015, 05:46 PM   #38
XYwagonAU
hi revcore,
Im actually wondering if the clockwise thing is true
I remember adjusting on left and right side is different
put handbrake on 2 clicks- then make adjustment
i would try levering wheel toward you drivers side
pushing wheel away from yourself passenger side
if handbrake is on it should tighten up quicker
get a torch to have a look through hole
cheers
Old 13-06-2015, 11:32 AM   #39
BLU-220
FG XR50 TURBO
BLU-220's Avatar
I have tried 2x attempts adjusting the handbrake on my AU XR8 and it's still the same as before
here is a shot how the handbrake leaver is, is this too high ??
and another thing it doesn't hold in any gear besides Park ??
cheers Dean
BLU-220 is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2015, 11:46 AM   #40
XYwagonAU
blu is yours a ute /wagon or sedan?
not sure if they are different but wagon doesnt have irs,
handbrake is like a drum brake inside a disc brake
so maybe take the disc off, check lining on handbrake
check spring etc,
clean it out
there is a picture below shows it inside
ps you want to keep adjusting until you cant turn disc around, then make sure it moves smooth when handbrake off (might have to back off adjustment)
good luck,
btw im not a mechanic so take with grain of salt.
cheers
Old 13-06-2015, 02:07 PM   #41
BLU-220
FG XR50 TURBO
BLU-220's Avatar
The XR8 is a sedan IRS
Old 15-09-2015, 06:29 PM   #42
ReeverDee
heya woosha you did this ^^^ on a BA model ? i ended up pulling the rotors of as there is no way to adjust through the little hole you spoke of when i pulled the rotors off the hole did not line up with the adjusting nut
ReeverDee is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2017, 01:02 AM   #43
rayhines
Yeah the hole does not line up well, you cant really see the adjustment wheel. But if you use a bent small screwdriver you can do it by feel - not easy.
I took off rotor, and worked out (by putting rotor back in reverse) where to drill a hole for adjustment with the rotor on.
It is not hard to drill a 10mm hole in the rotor (in area clear of holes) using a good quality high speed steel drill. Go 14mm if you have one.
Dean it only holds in park as the handbrake is not doing anything, it's the park lock pin working.
rayhines is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2017, 09:20 AM   #44
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Thread mine
UK
Mind you mine needs a tighten up too
Old 20-03-2017, 10:25 AM   #45
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
The only AU out of my four that has a handbrake that works well is the ute. The wagon one specially is useless. One day i'll give this a go.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2024, 02:40 PM   #46
adriantillin
adriantillin's Avatar
An oldie but a goodie - thanks Whoosha. Just used the original post to adjust mine. Shame the adjusters go different directions to tighten on each side. Easy on the passenger side but more difficult on the driver's side. Great handbrake now
Cheers Adrian
adriantillin is offline   Reply With Quote Multi-Quote with this Post
